1987 swivel head 3/8 ratchet F748.
Posted: Sat Feb 01, 2020 5:10 pm
by Scottcc
I found it in my inherited box. I took it apart and looks to have never been cleaned. I soaked it in mineral spirits, lubed it in Rem oil. It has a bit of first tooth slip after changing direction, but none after the first swing.
Re: 1987 swivel head 3/8 ratchet F748.
Posted: Sun Feb 02, 2020 3:22 am
by Scottcc
I took the ratchet apart and soaked it in mineral spirits. Then I used 20-50 oil to lubricate and put it back together. It fixed the skipping at least temporally. The inside ring has tooth impressions where the sprocket wheel presses from applying torque. Lots of wear, but is still working fine for now. I should have started the thread under repair and restoration.
Posted: Sun Feb 02, 2020 4:56 am
You probably should call Snap on and get a kit for it. Usually it is free.
Posted: Sun Feb 02, 2020 9:57 am
by Scottcc
I'll give it a try, but I think this has been discontinued for a while. Parts maybe hen's teeth by now.
Posted: Sun Feb 02, 2020 11:34 am
I looked, there is not a f748 kit listed. there is a f749 kit. But do call, the worst thing that could happen, is they say no. They may trade it out for a new one. But if this has value to you as it was your dads, then your only option may be to buy a rat on ebay and part it out.
Posted: Sun Feb 02, 2020 1:06 pm
by Scottcc
Interesting the F749 looks to have the same round head, but is fixed. I'll call and ask if the parts are interchangable.
Posted: Fri Oct 09, 2020 5:47 am
by HLAV1
No matter what that ratchet is guaranteed for life, hand it to your local truck and have them repair it or replace it?
