CJ66 Puller
Bill the Engineer
- Your Location: Coastal Delaware, USA
CJ66 Puller
Photos of my late Dad's CJ66 Puller. Any good suggestions how to clean this up? It's been sitting in a storage garage for years.
- CJ66 Puller.jpg (104.89 KiB) Viewed 2295 times
- CJ66 Puller ID.jpg (85.42 KiB) Viewed 2295 times
Re: CJ66 Puller
That's a old one. If it is rust, you can clean most of it with evapo rust, you can clean the shaft with a fine brass wheel on your grinder. I may have the third arm, what model number is it. It it is grease/dirt, spray it with simple green, and scrub it down with a med brush
- HLAV1
- Your Location: INDIANA
Re: CJ66 Puller
evapo rust
Bill the Engineer
Re: CJ66 Puller
I may still have the third arm. I need to spread everything out onto the garage floor for a good sort-out. I'll let you know if I end up one short.snapmom wrote:That's a old one. If it is rust, you can clean most of it with evapo rust, you can clean the shaft with a fine brass wheel on your grinder. I may have the third arm, what model number is it. It it is grease/dirt, spray it with simple green, and scrub it down with a med brush
