cooling system testers
Posted: Mon Jan 30, 2012 3:46 am
I've needed a cooling system tester for a while and I plan on buying one off the truck. I've been looking at the SVTS262 and the SVTS263A which are the standard and air powered cooling system testers. I like the idea of being able to aply shop air at a certain psi so you can walk around the vehicle without having to walk back and pump a few times. However, sometimes you find a need for a hand pump in other applications as well.
Does anybody have any experience with the air operated one ( the SVTS263A)? How well does it work? How is the regulator on it? I think i'm going to end up getting the air one, and then ordering the hand pump seperate at a later date.
