fixing kc556b slides
alwaysFlOoReD
Your Location: red deer, ab
Post by alwaysFlOoReD »
So I went to a few stores looking for steel strapping/banding. I thought it was a good idea but I guess the times are a changing....only plastic nowadays! I decided that I would try using an old hacksaw blade and grind off the teeth to make a slide removal tool. I put the blade into a vise and ground the teeth
worked great as long as you use a good quality blade, a cheap one shatters when you try to bend it slightly on the end like you need to do to make the tool.
Here is both sides of an original stop
While I was making the tool I saw the hole at the end of the blade and thought it looked close to the same size as the hole in the slide. I ground the blade to size and length
Give it a slight bend to match the original stop
The new piece goes through the hole and I used a nail as a rivet
The "rivet" has to be peened quite flat or the drawer won't close properly. I used a punch with a 1/4" round flat end to flatten the nail and ended up using my 16 oz finishing hammer to pound it flat enough. I used a scrap piece of 1/4" flat stock under the rivet head while peening.
I fixed 4 slides and my box is working like new again!
Richard
KR537D
Your Location: Georgia
Re: fixing kc556b slides
Post by KR537D »
Nice job! Let's see a pic of your box.
Users browsing this forum: No registered users and 27 guests
